Backup Error
hi i am new NAV6.0 so i would like to tell you when i did backup finsql 6.0 and restore into the fin 6.0 so again i try to back up the given error be occured…
Microsoft Dynamics NAV Classic
Caution: There is an error in the database structure. This occurs if the database file is changed by another program or if a device driver does not function properly.
You must correct this error before you can continue. The error (1190 in module 19) may have been caused by the computer or a program.
Table: Item
Company:
Key Fields: No.
Check the database. On the File menu, click Database, click Test, and then click Maximum. If you get the same error, you should:
  1. Back up the database by copying the database file or files to another location.
  2. Use the built-in functionality to make a backup.
  3. If this works, create a new database without deleting the database that contains the error or errors.
    Restore the backup that you made with the built-in backup functionality into the new database. To test it, on the File menu, click Database, click Test, and then click Maximum.
If this procedure does not work, then any database changes that were made after the most recent backup will be lost. Restore the most recent backup that was made with the built-in backup functionality and test it.
For security reasons, you should save the old database until you have used the new one for a period of time.
Contact your system administrator for assistance.
OK
Zip the backup & copy it to the computer where you are trying to restore the backup from.
