stan
June 24, 2011, 4:12pm
#1
hi all…
i have database which is have 3 companies
company A, company B and company C
the real live data is only in company A
so company B and C is just for the testing…
and then I only backup for Company A
after I restore to my computer… why it only have tables?
even though the menu designer is also empty
what’s wrong with my back up?
please advice… thanks
Please check the following:
Open Object Designer, Call Import function, change to “All Files” and point to your FBK-File.
The complete FBK also contains a FOB (at the very end, so it might take some time to process).
The most common issue for not importing the objects directly on Restore is that the database was not new (meaning the restore being the first action taken on the database).
stan
June 25, 2011, 12:09am
#3
when i create backup (for 1 company, there would be no problem)
but because i have 3 companies, so i untick the other two companies
every thing is the same… but when restoring, it become like this
Open Object Designer, Call Import function, change to “All Files” and point to your FBK-File. → is it when back up or restore?
Tvis
June 25, 2011, 10:21pm
#4
It should simply start reading the objects when you do this otherwise your fbk is corrupt.
I am unsure what you mean is it when backup or restore?
My advice would be to create a brand new database and then try to restore from the backup again and only choose the relevant company.
Just call “Import” from the File menu - like you would import a FOB file.
Then cahnge to “All Files” and point to your FBK.
A FBK file is actually the same as a FOB file.
