backcolour to field in form
Hi Friends,
I am trying to give backcoluor in some control in the form . I am using displayoption method on the form datasource.
with this code :
_options.affectedElementsByField(fieldnum(emplTable,Name));
_options.backColor(WinApi::RGB2int(182,220,233)); // light Blue
But this is not working , when i use
_options.affectedElementsByControl(EmplTable_Name.id());
it is working for this control only, my requirement is to colour at all places where this field is used.
pls help
thanks
Do anyone know what is DBFHdl2Int() function and how it is used
Instead of using display option() method, use active method.
Just change the auto declaration of the required cell to “Yes”…
lets say it is field1(name of the field in design)… in table1…
public int active()
int ret;
if (table1.stock == 0)
field1.colorScheme(FormColorScheme::RGB);
field1.backgroundColor(Winapi::rgb2int(255,0,0));
else
field1.backgroundColor(Winapi::rgb2int(255,255,255));
ret = super();
return ret;
This might help you… use the same for all the controls wherever it is necessary…
