Back up Problem
hi friend
The DB is 3.7 Indian version one i tryied to retore the backup(SQL) it fails R u Sure taking backup in SQL is correct.
regurds
satheesh
Yes I am sure. Take your NAV product cd and look in a folder called ‘Doc’. In there you will find a document called ‘w1w1isql.pdf’, which is the NAV installation manual for the SQL Server option, and it should have a section about restoring and backing up using SQL Server.
