Back and restore the application
Is there any way to backup the application itself and then restore it to a different machine? The new equipment may or may not have the same type of hardware but the operating system will be the same. If isolating the application alone is problematic can I back up the entire application with all the related files and databases? The end result is that in the event that the server becomes inoperable then the backup of the application can be restored onto a different machine without having to do a reinstallation.
Hi Mbl73,
Can you please report this in the correct forum below? Maybe NAV Technical, but it may well be SQL or AX, I’m not sure you’ll have to let us know.
This area is for more “Community” related posts.
/TH
