Currently you can find this in the administration manual for setup, the development manual for guides on new workflow (only 8 or 10 are standard) and then there are references to this in the Whats New manual. There is also a White Paper.
As yet Microsoft have not released a work flow specific manual, and I have no idea if they intend to, you would need to ask them.
White papers are written to express concept, Manuals tell you how it works, when the software is written the White paper is redundant because the manual will replace it.
Well in AP it is the third option under Setup, and fourth in AR.
You need to start configuring it and look at the conditions set etc.
I cannot teach you this from the ground up in a post like this.
Look at the purchase order workflows, start setting the elements of the version the conditions can be on the value and you have a whole range of group and user configurations.
I searched the partner source for that white paer, I could not find .
Could u throw that white paper to me or just upload that white paer in downloads.
I cannot upload it and I cannot send it because you need to have been given permission by Microsoft to do this, all I can do is give you the link, then if you have the appropriate rights you can see it.
Also not sure how hard you “searched” partnersource - if you search on Workflow with the functional area being AX there are only 58 entries, and this is the third. [:D]
