Axapta2009 and client logon
I have to close this.
Hey…
just chk this…
In the Run command → give services.msc
it will list u all the services thats available in ur sys…
check whether Dynamics AX Object Servies is ther… and also check if its service is started.
If it is not started… change the setting from automatic to manual… and start/stop it.
this will work… beacuse i get the same error sometimes… and i stop/start the service of AX manually when needed.
could it be because of the firewall on the client ?
