I have attempted to install Axapta 3.0. However, when I try to access the application I receive the following error: “No Navasion Axapta Object Servers could be located using the current client configuration” In my efforts to find the issue, I realized that the Object Server within the ‘Navision Axapta Server Manager’ was not running. When I try to start the Object Server it starts but immediately stops. Are these issues related? Any thoughts on how to resolve either, both of these issues? Thanks for your assistance.
HI jpax, the process is first install axapta in two teir. compile it , synchoronize it. The install AOS and in the configuration setting use AOS server with its defult name & properties. It will run, i think this is already address in this forum please check out all forum related to AOS. Thank you Regards Vaibhav
Thanks for your assistance. It is now successfully installed.
