Ax4 and AX 2012 R2 clients could be installed in the same PC
Thanks !!
I am not sure what issues you will get with this side by side installation.
There was a known issue with AX 2009 and AX 2012 installation on 64-bit which you can read here. I don’t remember .NET framework requirement for AX 4.0; but I guess this might cause an issue.
Did you try doing this? If not please try and let us know if you have any issues.
