Ax2012R2: Is it possible to generate Payroll against the hours that have been entered by the employees using Time and Attendance module?
Hi All:
What I have identified so far is that Time and attendance does not contain payroll processing functionality, but we can generate a payroll file containing calculated pay based on workers registrations, their work time profiles and the pay agreements to which they are connected. The payroll file can be imported into a payroll system and used as a basis for generating payroll records.
Regards
Zubair
Even i have the same question can the same be done.
Regards
Sujeet
Which version of AX are you using?
We are using Ax 2012 CU7
I am not sure there is an unanswered question there - they ask the question and then describe how to do it.
