Dear All,
I created SSRS in AX2012 successfully and i saw the preview in VS and build the solution and add to AOT all are successfully completed.when i try to deploy the report one warning and one error comes
The default Report Server Configuration ID could not be found in the SRSServers table.(warning)
Make sure that Microsoft Dynamics AX Business Intelligence Components are installed on the SQL Server Reporting machine and verify that SQL Server Reporting Services is configured correctly matching the report server configuration in the Microsoft Dynamics AX client. (error)
today only i face this issue.yesterday i created and deployed successfully. please give me the solution as early as possible
