AX2012 R2 CSV File name reading
HI All,
i have a question in ax2012 r2.I want to read the .CSV file name from particular folder.
I.e i have a number files in temp path. i want to read all the file names and if any file name math with my query i want to take that file from temp path.
EXAMPLE: File names are GroupABC,
GroupXYZ,
GroupMNO,…)
In my query file name seems XYZ…i want to use the 2nd file…
Can you please help me how to take that file from location.
I would use System.IO.Directory::GetFiles() through .NET Interop:
System.Collections.IEnumerable files;
System.Collections.IEnumerator enumerator;
str fileName;
files = System.IO.Directory::GetFiles(@'C:\TEMP', "*XYZ");
enumerator = files.GetEnumerator();
while (enumerator.MoveNext())
    fileName = enumerator.get_Current();
    info(fileName);
