I have uploaded following tables.
EcoResProduct,EcoResProductTranslation,InventTable,InventItemGroupItem,InventmodelGroupItem,InventTableModule,InventItemLocation,EcoResStorageDimensionGroupItem, EcoResTrackingDimensionGroupItem
Now I can see the items in the All items as well as in released items.
But when I try create a purchase order I can not see the items in the drop down of purchase orderline.
same thing os obseved in the formula lines.
2.When I try to approve the formula by selecting a employee I get following error:
“employee is not a registration worker or is not active”
I dont find any option to active the employee in the HR module>Employee
If you are a partner, I would suggest you check with your contacts regarding the import tool which currently is in pre-alpha version. And see whether that is of any help to you because there are some code snippets available in this tool.
