AX2012 HR module
I have below error while deleting the job that I created.
“Jobs cannot be deleted while dependent Position details exist. Delete dependent Position details and try again.”
Those job have assigned to position and assigned to worker. I tried to delete position before delete jobs. But I have below error too.
“Positions cannot be deleted while dependent Position worker assignments exist. Delete dependent Position worker assignments and try again.”
Can anyone help? Please~~
Zee
There seems to be position hierarchy built in the system. Let’s say position 1 reports to Position 2, If you try deleting position 2 system will not allow because position 1 is trying to report position 2.
Remove the link between positions. i.e., position 1’s reporting to position field" set it to “blank”. Then try deleting the position.
