sanax4l
February 29, 2012, 3:35pm
#1
There is a new feature in production module listed for AX2012 which is as follows:
"Monitor inventory using dual units of measurement (UOMs) to manage total weight as well as packaging units (catch weight calculations). "
Can some body tell me how this functionality is working.
You hold items in dual weights, a pack and kg’s for example and you set a range of weight for the KG, bit like how you buy chicken breasts, steak or fish, then you can see inventory by weight and packs.
how can I use this feature?
You activate catchweights when you need to track a product in 2 UOM’s, weight and packaging is the obvious. You use it when your client requires it.
Babu_A
January 3, 2016, 1:58pm
#5
How to active two UOM for same product.I need to maintain item BOX wt and item PC wt
No that is a completely different concept to catchweight, please post a new question.
Babu_A
January 3, 2016, 6:48pm
#7
How to Maintain single piece of item weight in ax 2012 R3.
like have 1 box=10 pieces total wt is 10 kg.
Each pieces have 1 kg. How to map the single piece of wt in Ax
Load a new post as suggested. What you are asking here is no related to the original post, so people will not look.
