ax2012 Data Import & Export Framework
In Ax 2012 R2, I create a simple table with Id and Description (2 fields). Then i use the Data Import & Export Framework wizard to create the DMF entity for the new table. I successful import the data into the staging table using csv file. However, when i run the “Copy data to target”. It only able to create the 1st record into target table, the others records give message " ‘xx’ records updated". Anyone face this issue?
May i know why it show “UPDATED”? But record it not insert into target table? How to resolve this. Pls advice.
Thanks.
KY Tan
