We are using AX2012 CU7 and we would like to update the desktops to Windows 10. We updated a few desktops and sometimes we are facing with the problem dat AX directly crashes at startup. I know CU7 is not supported by Microsoft, so solution from business partner is to upgrade to CU8
Does anyone know what a solution from this problem can be? And if CU7 will be supported by Microsoft in the future?
Maybe we can fix it with an hotfix instead of a complete (expensive) update to CU8.
Thanks in advance!
Which release of AX 2012 are you talking about?
If you want to look for a solution, you would have to tell us more about the problem, such as the content of event logs. Nevertheless CU7 is pretty old, therefore you should consider an upgrade anyway.
Hi Martin,
I am talking about AX2012 R2 CU7.
I get the following errors in my eventlog;
.net runtime
Toepassing: Ax32.exe
Framework-versie: v4.0.30319
Beschrijving: het proces is beëindigd als gevolg van een onverwerkte uitzondering.
Uitzonderingsinformatie: System.Runtime.InteropServices.SEHException
bij ._wWinMainCRTStartup()
Application error
Faulting application name: Ax32.exe, version: 6.2.1000.8425, time stamp: 0x53b69473
Faulting module name: KERNELBASE.dll, version: 10.0.10586.162, time stamp: 0x56cd55ab
Exception code: 0xe06d7363
Fault offset: 0x000bdad8
Faulting process id: 0x1480
Faulting application start time: 0x01d1a149949c97c6
Faulting application path: C:\Program Files (x86)\Microsoft Dynamics AX\60\Client\Bin\Ax32.exe
Faulting module path: C:\WINDOWS\SYSTEM32\KERNELBASE.dll
Report Id: d5ba44bd-0d3c-11e6-89d9-b46d834a9637
