There are 3 types of costing versions.
- Planned cost
- Standard cost
- Conversion costs - A special costing version used for converting an item from a non standard cost costing method to the standard cost costing method.
I tried to create new costing versions for the type “Conversion”. But error message prompt. May I know how can i create this type? What is the used for conversion costs?
Path: DTS/Inventory management/Inventory management Area/Setups/Costing versions
Lee
Yes that type of costing sheet is created as part of the standard cost conversion routine - why do you want to create one? If you run the process it will do it, if you do not run the process you do not need one!
Hi Adam,
I don’t really understand. How to run the process and make it do it? In what scenario I will need to use the costing type “conversion”?
Lee
Are you converting the costing method of any of your items from non-standard to standard? If you are NOT you would not use this. Search google for AX2009 standard cost conversion, there are white papers and lots of information on this.
