AX2012 Automatically create barcodes in 6.1 Retail
AX2012 Feature Pack (6.1 Retail) gives you the function to automatically create or update barcodes for an item or create by help of a number sequence.
Select a released product > Tab ‘Manage inventory’ > Barcodes > Functions: Create barcodes from number sequence.
But somehow, it does not work.
When i enter the same form and function via the retail module, an error occurs ‘Window must be called with parameters’.
I can not find a number sequence either. Who can help me out?
you should specify number sequence for specific vendor , go to vendor form in retail tab you will find number sequence field specify your number sequence and go to barcode screen and press create barcode from …
