[AX2012] add field to sales packing slip
now i have add field in sales line (remaks) and also in CustPackingSlipTrans. But i cant make the data transfer while posting packing slip.
i had write the code in custpackingsliptrans.initfromsalesline(), and SalesPackingSlipJournalCreate.updatejouranlline(). but it still no function, breakpoint also no function in those method.
can anybody help to me or guide me this problem? Thank you.
I think it’s safe to assume that your breakpoints don’t work because the logic runs in CIL and you’re using the X++ debugger, which indeed won’t work. You have to either use a CIL debugger, such as Visual Studio, or (for testing purposes only) to disable CIL execution in user options.
And if you’re not aware of CIL, you likely didn’t re-generate CIL after your changes, therefore CIL doesn’t contain your changes.
