AX2009 - Write off bad debt
Hi there,
What is the steps to write off a customer outstanding balance or invoices ?
Any response will be much appreciated
Sales Ledger > Common > Customers > Open the particular customer .
Select Collect Tab :
Press button Writeoff .
Before that you need to configure accounts for writeoff
Thanks for the quick reply. But is this for AX2009 environment ? I cannot find the menu path mentioned in your reply ?
and where exactly I should set up the configure accounts ?
In UK localization Accounts Receivable is Sales ledger . In your AX System you go to :
Accounts Receivable > Common > Customers > Open the particular customer (For which you need to do write off)
Thanks for the prompt reply, however, I don’t think the “WriteOff” button is available in the AX2009 version. Thanks again
Yea I thought it was AX 2012 .
