AX2009 workflow element events
In AX2009, I’m having trouble understanding the different workflow events and when they are triggered.
My information source is http://msdn.microsoft.com/en-us/library/cc588240(v=ax.50).aspx
I’m unable to find the answers in the Microsoft documentation, or on the internet.
Unfortunately, no-one in our company has any technical experience with workflow development, so I cannot ask a colleage.
That’s why I’m posting my question here, in the hope that someone can shed some light on this.
I know there are basically 4 WorkflowElement outcome types:
AOT name in case of
AOT name in case of
Outcome Type
Task
Approval
Complete
Complete
Approve
Return
Return
Reject
RequestChange
RequestChange
RequestChange
Deny
Deny
Deny
In the AOT, there are properties on workflow and its elements to enter the EventHandlers.
LEVEL
Object property
Workflow
CanceledEventHandler
CompletedEventHandler
ConfigDataChangeEventHandler
StartedEventHandler
WorkflowElement (Task/Approval)
StartedEventHandler
WorkflowElementOutcome
EventHandler
In case of the Element Level event handlers, I’m confused.
This is where I think the EventHandlers should be entered:
Event
On WorkflowElement
properties
On WorkflowElementOutcome
properties
WorkflowElementStartedEventHandler
yes
WorkflowElementCanceledEventHandler
yes
WorkflowElementCompletedEventHandler
yes (type=complete)
WorkflowElementReturnedEventHandler
yes (type=return)
WorkflowElemChangeRequestedEventHandler
yes (type=requestchange)
WorkflowElementDeniedEventHandler
yes (type=deny)
What is the difference between a Denied and Canceled?
When you Cancel a workflow, does that first trigger the Deny on the WorflowElementOutcome, and then the Cancel on the WorkflowElement?
Also, the documentation mentions: (note with Element Level Event Handlers)
The Return and ChangeRequested events share the same state in the recommended workflow state model. You can implement these two different events to distinguish between a workflow that is returned and a workflow that only needs a change. However, in both events, the behavior is the same in that a work item is created, and after the work item is complete, the document state is returned to Started.
I’m not sure what they mean here by “document state”. Do they refer to the “Workflow State” mentioned in “Approval State Transitions” (http://msdn.microsoft.com/en-us/library/cc604518(v=ax.50).aspx)?
If so, there’s no state “Started”.
Bjorn.
