AX2009 size of lookup field
I created a lookup field under grid form. The field fine and list the data but always when I dropdown this field it’s drops in a larg screen instead of showing the only the field without larg space.
Can you show an example and/or code needed to reproduce the problem?
Hi Martin,
Whenever selected the drop down it’s expanding like the below picture, the records are fine but every time try to select I have to scroll to the left to select.
My guess is that you simply have a very wide control in the lookup form.
Thanks Martin, what I did is change the size of the lookup field from the table field properties. Thanks a lot again.
