Hi ,
I have following issue in AX 2009 …
I have one Form .on that form i have one drop down. when you click on drop down it will show you some values.
user can able to select multiple values at same time using check box provided with value
Now problem is if we have multiple clients …lets say we have two client running . one of the client have opened the above form and select multiple value using check box in above drop down and at same time if another client open same form and click on drop down then he also able to see the values selected by first client in that drop down…
so now we don’t want second client to see what values are selected by first client when they try to open form and select drop down at same time.
any idea…any property we can apply for above problem…
Please guide me with solution as soon as possible…
Thanks and Regards,
Sunny…
