AX2009 Ax32serv.exe crashes when creating customer invoice in server batch
Hello,
we have a problem when creating customer invoices in a server batch.
The aos crashes nearly every 3 minutes when printing the invoices to an .rtf file.
In the Windows Application Event Viewer we find the entry:
Application Error 1000
Fehlerhafte Anwendung Ax32Serv.exe, Version 5.0.1500.1313, Zeitstempel 0x4ab446b1, fehlerhaftes Modul GDI32.dll, Version 6.0.6002.18005, Zeitstempel 0x49e04114, Ausnahmecode 0xc00000fd, Fehleroffset 0x0000000000007354, Prozess-ID 0x%9, Anwendungsstartzeit %10.
Any ideas what the reason could be?
Please can you translate the message in English? Also please provide Ax version details.
my translation is:
error in Ax32Serv.exe, timestamp 0x4ab446b1, error in modul GDI32.dll, exit code 0xc00000fd, error offset 0x0000000000007354, process-ID 0x%9
Thank you
And the AX Version is:
AX2009 Version 5.0.1500.1313
Per se this error doesn’t look coming from Dynamics Ax.
What printer / printer driver are you using? Can you try changing to another printer?
Thank you.
we are printing to .rtf file.
But we will try this scenario: First only create invoices via server batch.
And, if the server doesn’t crash: Print invoices manually afterwards.
Hi Harish,
we have tried the scenario:
first: booking only - that worked fine
then: printing the invoices - that failed
Now we have tried different printerdrivers and we found out: some printerdrivers work fine and others don’t work
Hello Kikiko,
That is what I thought. Printer drivers are the culprit. I always recommend my customers to test Ax 2009 with all printer drivers in the organisation before go live.
I am having the same problem. The AX service crashes while writing a file during batch processing only. Same AXversion too. I am confused on why this is a printer driver issue though because the server is writing ASCII (*.txt) file which should not be using a printer driver.
Faulting application Ax32Serv.exe, version 5.0.1500.1313, faulting module 4ab446b1, version Ax32Serv.exe, fault address 0x5.0.1500.1313.
To try to pretend it is a printer issue, I used Options to change it to various printers and then switched back to printing ASCII, but it always crashes on some AOS servers. I this case it is my virtualized servers that are having problems and the one non-virtual server works fine.
