Server : Microsoft windows Server 2009 R2 Datacenter edition
Database: Microsoft SQL Server 2008 Enterprise Edition SP1
the user is Administrator everywhere, service is not starting and the below is the error message:
Object Server 01: The home directory for Axapta (c:\Folder\ax64\Application) does not match the required structure or can not be accessed. Please check installation, configuration and access rights.
Looks your folder structure (i.e. physical aspect) has not been set up correctly. Suggest to copy Ax folder setup from a working installation and replicate the same.
