Hi, I can’t update sales order by AIF using the following XML file.
Message says that “Cannot update record - the record does not exist.”.
And this message is @SYS112449.
<?xml version="1.0" encoding="utf-8" ?>
schemas.microsoft.com/.../Message">](http://schemas.microsoft.com/dynamics/2008/01/documents/Message)
contoso\Administrator FileAdapter LocalEP [schemas.microsoft.com/.../Action>](http://schemas.microsoft.com/dynamics/2008/01/services/SalesOrderService/update) schemas.microsoft.com/.../Message">](http://schemas.microsoft.com/dynamics/2008/01/documents/Message) schemas.microsoft.com/.../EntityKeyList">](http://schemas.microsoft.com/dynamics/2006/02/documents/EntityKeyList) schemas.microsoft.com/.../EntityKey">](http://schemas.microsoft.com/dynamics/2006/02/documents/EntityKey) SalesId SO-101253 schemas.microsoft.com/.../SalesOrder">](http://schemas.microsoft.com/dynamics/2008/01/documents/SalesOrder) <_DocumentHash>5c6d97a737419b29e23c69a70765fba0 2012-04-29 1 1001 5 ea ----------------------------------------------------------------------------- Although the document read by AIF is as following. ------------------------------------------------------------------------------ <?xml version="1.0" encoding="utf-8"?> schemas.microsoft.com/.../Message">](http://schemas.microsoft.com/dynamics/2008/01/documents/Message) {E6D579B1-1C3F-40D5-858B-255CB17F83A4} LocalEPFileAdapter [schemas.microsoft.com/.../Action>](http://schemas.microsoft.com/dynamics/2008/01/services/SalesOrderService/read) {A5BF71EF-100F-4DA2-B342-A65DD51C08C3} schemas.microsoft.com/.../Message">](http://schemas.microsoft.com/dynamics/2008/01/documents/Message) schemas.microsoft.com/.../SalesOrder">](http://schemas.microsoft.com/dynamics/2008/01/documents/SalesOrder) <_DocumentHash>5c6d97a737419b29e23c69a70765fba0 2012-04-27 10031.00ea 10011.00ea ------------------------------------------------------------------------------ Therefore I can't imagine the reason of the above error . This error ocuurs in the deserializeSubEntitiy method of the AxdBase class.Actual line of error is 61 and this caused by the empty result of the following command. I checked the _dataSourceName then found that it is "SalesLine".
// Find the corresponding existing record
entityEntry = this.findEntityOnCurLevel(_dataSourceName,_axInternalBase);
Does anyone have any idea of solving this problem.
