AX V4 Project Purchase Orders
Does anyone know if it is possib;e to move PO’s between Projects after they have been raised and if so, how is this achieved?
As long as the POs are not Receipted or Invoiced, you can change the Project ID from PO Line details=> Project tab.
Thanks for the reply. However, as soon as I raise a PO against a Project, the Project field on the Project tab of the PO Line is ‘greyed out’ and I cannot update it. Similarly, I cannot update the Project field on the PO Header. This is with to transactions whatsoever posted against the PO.
Sorry, that should read ‘no transactions’.
I see. Usually the field would be editable. Check if there are any customizations done on that!
By the way what is the version of your AX? Can paste any screenshot here for reference??
[View:http://dynamicsuser.net/cfs-file.ashx/__key/CommunityServer.Discussions.Components.Files/119/1263.Open-Purchase-Order-associated-with-Project.docx:550:0
HI, it is V4. As far as I know there is no customisation around this function.
