Hi i am getting this space in my report even though there is no space given in report design is there a way to get rid of it .
above is the design now below is the report generated.
the arrow denotes the space which is not required …Thanks in advance
Hi Vinesh,
Add all these textboxes in one rectangle and after that check each textbox’s parent property it should be the name of newly added rectangle
Thank you Kedar but the troublemaker was the address field which was beside the design
when i dragged it vertically below the space problem was resolved it was actually occupying
the right side area causing trouble for other design…
