Ax server configuation
Hi guys
i installed ax 4.0 in my machine
unexpectedly i gave DB connection to Sql Db
total process is completed
i need to change Data base
so finally i find in All program’s>> Administrative tools >> Microsoft dynamics Ax server configuration Utility >> DataBase connection
but here that page is not enable
Note : Its licensed version
can any one help
Hi Ven Benz,
In Control Panel — Administrative Tools — Microsoft dynamics Ax server configuration Utility … there you cana find the “Manage” button over there you can find the option “Create Configuration File”.… then you can change the DataBase name on the DataBase Connection Tab…
