AX Security on forms
I have a form that will be opened by double clicking on a field and this does now have a menu item attached. Its been called by passing the form name to args. I need to set security for this form for some user groups via ‘User group permissions’ but I cannot find this object in the security tree. can someone can please tell me how I can locate this object?
Security is configured for menu items, not forms, so you can’t see a form in the security tree.
Hi Martin, I understand that, If I want to configure security in a scenario like this, how can I do it?
If you want to use configuration in User group permission, you simply have to use a securable object, i.e. a menu item. It may be, for example, used by a hidden menu item button in the form.
