AX Retail 2009 Question
I created a new table on the HO and POS, the data replicated from HO to the POS successfully, but when I try to pull the data into the HO, no data inserted in the table, the pulling of standard tables are working correctly,
I checked the —R.tmp (package file) on the POS, I converted it to xml using package viewer, I found that it is not contain any data
this is the R.tmp file:
<?xml version="1.0" encoding="UTF-8"?>
Any suggestion about this problem,
