AX Report - Select button not showing up
Hello,
I enabled access to a report (Project Module | Reports | Attendance) for a group of users; the only problem is that the Select button isn’t showing up, so they can’t choose the fields they want. Do you have any insight into where I should look to enable that button? By the way, the Select button isn’t showing up on any of the other reports for that group of users either. Any ideas would be appreciated.
Thanks!
