Ax report, rotate 180 degree property
I need to know which property to be used for ‘Rotate 180 degrees’ during report print. The manual process is shown below,
During the printing of a report, Intermediate screen is displayed as below
When we click on ‘Properties’ button, ‘Print properties’ screen gets open. Under ‘Finishing’ tab, an option ‘Rotate by 180 degrees’ is available. see the following screenshot
Through this we can rotate the report by 180 degrees.I want to use ‘Rotate by 180 degrees’ property through code.How can I achieve this through code ?
Thanks in advance,
Raghav.
