From the server event log: – Any Idea what could be the cause? is there any fix for this? We use AX 2012 FP. Thank you
C:\Program Files\Microsoft Dynamics AX\60\Server\IronAX\Bin\Ax32Serv.exe
C:\Windows\assembly\NativeImages_v4.0.30319_64\mscorlib\5a23c5e185cb978f73c67718f6e061a4\mscorlib.ni.dll
d5d918ed-98d1-11e2-940d-00155d021d03
******************************** .NET Run Time Error **********************
Application: Ax32Serv.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.AccessViolationException Stack: at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(System.ServiceModel.Dispatcher.MessageRpc ByRef) at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(System.ServiceModel.Dispatcher.MessageRpc ByRef) at System.Collections.Generic.GenericEqualityComparer1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].GetHashCode(System.__Canon) at System.Collections.Generic.Dictionary
2[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].FindEntry(System.__Canon) at System.Collections.Generic.Dictionary2[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].TryGetValue(System.__Canon, System.__Canon ByRef) at Microsoft.Dynamics.AX.Framework.Services.QueryService.QueryProcessor+FieldProcessor.Process(ProcessorArgs) at Microsoft.Dynamics.AX.Framework.Services.QueryService.QueryProcessor+DataSourceProcessor.Process(ProcessorArgs) at Microsoft.Dynamics.AX.Framework.Services.QueryService.QueryProcessor.FillFlatDataSet() at Microsoft.Dynamics.AX.Framework.Services.QueryService.QueryProcessor.FillDataSet(Microsoft.Dynamics.AX.Framework.Services.QueryService.Paging ByRef) at Microsoft.Dynamics.AX.Framework.Services.QueryService.QueryStream.GetFirstDataPage() at Microsoft.Dynamics.AX.Framework.Services.QueryService.QueryService.ExecuteStreamedQuery(Microsoft.Dynamics.AX.Framework.Services.Metadata.Contracts.QueryMetadata, Microsoft.Dynamics.AX.Framework.Services.QueryService.Paging) at DynamicClass.SyncInvokeExecuteStreamedQuery(System.Object, System.Object[], System.Object[]) at System.ServiceModel.Dispatcher.SyncMethodInvoker.Invoke(System.Object, System.Object[], System.Object[] ByRef) at System.ServiceModel.Dispatcher.DispatchOperationRuntime.InvokeBegin(System.ServiceModel.Dispatcher.MessageRpc ByRef) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage5(System.ServiceModel.Dispatcher.MessageRpc ByRef) at System.ServiceModel.Dispatcher.ImmutableDispatchRuntime.ProcessMessage31(System.ServiceModel.Dispatcher.MessageRpc ByRef) at System.ServiceModel.Dispatcher.MessageRpc.Process(Boolean) at System.ServiceModel.Dispatcher.ChannelHandler.DispatchAndReleasePump(System.ServiceModel.Channels.RequestContext, Boolean, System.ServiceModel.OperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.HandleRequest(System.ServiceModel.Channels.RequestContext, System.ServiceModel.OperationContext) at System.ServiceModel.Dispatcher.ChannelHandler.AsyncMessagePump(System.IAsyncResult) at System.Runtime.Fx+AsyncThunk.UnhandledExceptionFrame(System.IAsyncResult) at System.Runtime.AsyncResult.Complete(Boolean) at System.Runtime.InputQueue
1+AsyncQueueReader[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].Set(Item<System.__Canon>) at System.Runtime.InputQueue1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].EnqueueAndDispatch(Item<System.__Canon>, Boolean) at System.Runtime.InputQueue
1[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].EnqueueAndDispatch(System.__Canon, System.Action, Boolean) at System.ServiceModel.Channels.SingletonChannelAcceptor`3[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089],[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]].Enqueue(System.__Canon, System.Action, Boolean) at System.ServiceModel.Channels.ConnectionDemuxer+CompleteSingletonPreambleAndDispatchRequestAsyncResult.OnPreambleComplete(System.IAsyncResult) at System.Runtime.Fx+AsyncThunk.UnhandledExceptionFrame(System.IAsyncResult) at System.Runtime.AsyncResult.Complete(Boolean) at System.ServiceModel.Channels.ServerSingletonPreambleConnectionReader+CompletePreambleAsyncResult.OnWriteCompleted(System.Object) at System.Runtime.Fx+AsyncThunk.UnhandledExceptionFrame(System.IAsyncResult) at System.Net.LazyAsyncResult.Complete(IntPtr) at System.Net.Security.NegotiateStream.StartWriting(Byte[], Int32, Int32, System.Net.AsyncProtocolRequest) at System.Net.Security.NegotiateStream.WriteCallback(System.IAsyncResult) at System.Runtime.AsyncResult.Complete(Boolean) at System.ServiceModel.Channels.ConnectionStream+IOAsyncResult.OnAsyncIOComplete(System.Object) at System.ServiceModel.Channels.SocketConnection.OnSendAsync(System.Object, System.Net.Sockets.SocketAsyncEventArgs) at System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object) at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationSuccess(System.Net.Sockets.SocketError, Int32, System.Net.Sockets.SocketFlags) at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallback(UInt32, UInt32, System.Threading.NativeOverlapped*) at System.Threading._IOCompletionCallback.PerformIOCompletionCallback(UInt32, UInt32, System.Threading.NativeOverlapped*)
