HI , can anybody review this Query ?
Select all items in saleslines that has a configuration(inventory dimension) specified in transactions
SalesLine salesLine;
InventDim inventDim;
InventTable inventTable;
while select inventTable
exists join salesLine
where salesLine.ItemId == inventTable.ItemId
exists join inventDim
where inventDim.inventDimId == salesLine.InventDimId
&& inventDim.configId != ’ ’
info(salesLine.ItemId);
Hi Jagaddish,
I dont have any idea why you are taking inventtable in to the loop. Instead you can write the query like this :
while select salesline
exists join inventtrans
where salesline.itemid == inventtrans.itemid
exists join inventdim
where inventtrans.inventdimid== inventdim.inventdimid
info(salesline.ItemId);
HI ,
How can i use , delete_from , forupdate and delete commands in QueryObject ax 2009…
can we have any static Queryclasses to perform above operaions like (OrderMode,Selection FIeld …etc.).
Hi Jagaddish,
Generally query (qbds) can be written in order to filter the data in forms.
Or some complex repoort or enquiry purpose you can initiate writing Queryclasses code.
But for deletion, you can use simple select statement.
And the query class can also be used to clear the ranges in your form (using clearranges()).
HI vishal …
you are suggested me that , use normal select statement to perform delete operation…so i have written the query object like the below.
could you please verify it…
while( queryExecuter.next())
salesTable = queryExecuter.get(tablenum(SalesTable));
delete_from salesTable;// it’s not working
salesTable.delete();// it 's working
info(“Orphan records are deleted”);
