I have installed ax pos successfully, but it showing A System error has occured.The application will shout now.
This error message is displaying.
Please help me on this issue.
Srinivasn
Srinivasn
Please tell us which version of AX you’re talking about, what you have found in event logs and so on. If you don’t provide enough information, you can’t expect any answer.
POS failed to refresh tracing configuration and will no longer produce tracing events.
Exception: Configuration system failed to initialize.
This is the exception i have seen in event viewer.
The ax version is AX 2012 R3.
Srinivasulun.
