I am trying to run a trace on a process in our development environment. When I start it, I can see in the command prompt that it is running. Problem is, it never creates the log files. The Event Viewer shows this error but I cannot find what it means.
Session “AX_TRACE_client_{CE6D980E-3F17-490A-951F-ECE4BE57A597}” failed to start with the following error: 0xC0000022
I adjusted all the registry values as suggested by Microsoft. Same with the Server and Client Configurations.
What if you run it with administrative privileges?
Same, no log files created.
Please verify that you didn’t miss any step in configuration. Most importantly:
Security Considerations for Tracing:
- The account running the AOS instance must belong to the ‘Performance Log Users‘ local group or the Administrators local group on the AOS if it is running on Windows Server 2003 or Windows Server 2008. The WMI event tracing subsystem requires that tracing be started only from a user belonging to one of these groups.
- The client trace is initiated by the currently logged on user, so verify that user has access to the log path defined in the client configuration utility.
- The server trace is initiated by the account running the AOS instance, so verify that user has access to the log path defined in the server configuration utility.
