Dears,
An error show every time I try to fill form on EP using tab to brows fields.
An error has occurred because a control with id could not be located or a different control is assigned to the same ID after post back.
this error didn’t appear if I use the mouse to brows fields, it’s only show if I use the tab.
Note: please note that I add a static control ID for all controls on the form.
