Ax Development
Hi, I am very new to Ax. I just want to do small thing by creating three forms in a project Hotel Management.
first form is regarding books.
second regarding Reservation.
Third regarding Booking.
I know its asimple thing but as i am so confused from where i have to start.
Start with analyzing the requirements.
Then design your data elements(Tables,DataTypes) and UI according to your requirements.
If you are not a developer get trained on the X++ developmentā€¦
Not sure what you have any other programming background. If you havenĀ“t, first familiarize yourself with fundamental programming concepts such as client/server model, design patterns, SQL operations, OOP etc. Afterwards do X++ programming course in DAX.
In order to be an efficient programmer, you need to have knowledge in the above areas before starting with DAX.
