AX is currently printing the date in the following form on sales invoices: 09.10.2012 (09 October 2012).
We would like to have the date printed as follows: 09 Oct 2012.
How can that be reaslized?
Hope somebody can help.
Thank you.
Ludwig
Thank you.
Ludwig
You should have a look to your date field’s properties in your report design: mix the differnet properties to have the format you want
Thomas
Hello Thomas,
Unfortunately, changes in the fields properties do not help. The only thing I am able to do is to change the sequence of day, month and year.
Though, the month is still displayed as a number (10), not in form of letters (Oct).
Hope you can help.
Ludwig
Hi Ludwig,
Just go to the report design n choose the date field…
Under properties u can find “Date Month” , In that choose the following “Short name (first three letters)”.
This will help u …
Madhan
Hello Madhan,
Thank you for that information.
What you describe works perfectly in Standard reports.
Yet, in the report I have to adjust, another developer used a ‘date2Str’ function where he calculates a date value.
I can change the sequence of the DAY, MONTH and YEAR fields that are printed on the report.
Yet, I have no idea how to convert this string into a date field that shows the short name of the month.
Do you have any suggestions?
Ludwig
