Hi friends when taking product back up this error will be occurred
Error: Cannot find table Parent for FieldId SrcFieldId in the table SysSearchRef
how to solve this please guide me.
How are you doing the backup? It obviously isn’t a normal database backup.
And what’s the version of AX?
Hi Martin,
we are using Ax 2012 r2
Thank you, but I still have no idea what you’re backing up and how.
Back up for sql database
I am doing like this from sys admin-----Data export to----giving file name----save
I dont know exactly how to take AX back up in 2012 version. There are 3 databases in ax 2012 how to get back up from those.
Please guide me.
Thanks in Advance,
Ranchoo
Exporting data is not the same as backing up a database. When you import data, they’ll likely be different (e.g. RecId or createdBy fields), it may fail (e.g. import tables in a wrong sequence), it’s slow and so on.
If you want real backups and the ability to restore a database in exactly the same state as it was when backing up, you have to use backup features of SQL Server. Understanding SQL Server Backups may be a good place to start.
