AX 7 login issue
Hi experts,
I am facing issue to login to AX7 environment and need help.
I tried with AX7 CTP8 VM available; performed following steps
It throws a message that this is an unauthorized user and revert me back to the login page. After couple to attempt, it temporarily blocks the account
I tried to create AX7 environment using LCS with following steps
  • Created a new project in LCS
  • Created a new AX7 environment
  • I am able to open the VM using the credential provided in the LCS portal
But whenever, I am trying to open AX7 using my LCS credential, same message is popping up.
Any help will be appreciated.
Krish
Use your Office365 account, not administrator@contosoAX7.onmicrosoft.com.
Thanks Martin for your quick response.
But I am still getting the same error message while loading AX that the user is unauthorized and it reverts me back to login page.
While trying to resubmit my office365 id, I got a new error message
You can find the batch services among normal Windows services.
I don’t have CTP8 anymore; don’t you want to use RTW instead?
Is the VM already available for RTW?
It is. I downloaded it from Connect on Saturday.
