Hello all,
I am beginning to troubleshoot an issue on AX4 in which a PO is confirmed and then directly updated to invoice status via code.
In many cases, the process works flawlessly. In a few, seemingly random, cases it will update the document status to Purchase Order, and then it will update several of the PO Lines to Invoiced status, but not all.
The code is wrapped in a transaction, so I don’t believe an error is being thrown. Below is the code, if you have any suggestions or ideas on how it could be possible that some lines are invoice updated while others are not, I am all ears!
Grazie,
S
invoiceNum = “Inv_” + pOrder.PurchId;
//Post PO
pflPo = PurchFormLetter::construct(DocumentStatus::PurchaseOrder);
pflPo.update( pOrder // Purchase record Buffer
, invoiceNum // Packing Slip Number
, systemdateget() // Transaction date
pOrder.reread();
if (pOrder.DocumentStatus == DocumentStatus::PurchaseOrder
|| pOrder.DocumentStatus == DocumentStatus::Invoice)
//Post PO Invoice
if(pOrder.DocumentStatus == DocumentStatus::PurchaseOrder)
pflInvoice = PurchFormLetter::construct(DocumentStatus::Invoice);
pflInvoice.update( pOrder // Purchase record Buffer
, invoiceNum // Invoice Number
pOrder.reread();
