This is my first post - is there any way of editing the std system lookup method for PriceGroupId instead of overriding the lookup method on each instance where the field is displayed across the system?
I’m confused on the question. Yes? Just edit the standard system lookup for PriceGroupId? Are you sure you’re not looking for the CustPriceGroup or the VendPriceGroup EDT?
Look at those EDTs and check the relations to see how the lookups are being performed. Depending on what you’re doing, it might cause some other issues down the line. You can add a “FormHelp” to make the lookups go to a form.
