Can someone advise me how to configure if an item will produce different quantity in a hour which dependent on what machine is being used?
Here is the scenario. We have 2 items (I1, I2) and 2 machines (M1, M2). If I1 is processed using M1, then, within a hour it will produce 10, but, if I1 is processed using M2, then it will produce 9. If I2 is processed using M1, then it will produce 12, but, if I2 is processed using M2, it will result 11 in a hour.
If we use capacity as route consumption formula, it will ignore processed quantity in route operation, right? CMIIW
If we use batch as route consumption formula, it will ignore resource capacity, right? CMIIW
If we use resource batch as route consumption formula, it will ignore processed quantity in route operation, right? CMIIW
If that’s the scenario, can someone advise me, how we configure our route consumption?
Jefry
