AX 2012 Transfer number sequence framework tables.
While executing the Launch data upgrade (BCP) in AX 2012, i am getting the error
Microsoft.Dynamics.Ax.Xpp.ErrorException: Exception of type ‘Microsoft.Dynamics.Ax.Xpp.ErrorException’ was thrown.
at Dynamics.Ax.Application.NumberSeq.numRemoveFormat(String num, String format) in NumberSeq.numRemoveFormat.xpp:line 16
at Dynamics.Ax.Application.ReleaseUpdateDB60_Basic.Upgradenumbersequencetables(Boolean _remapEdts, Boolean ) in ReleaseUpdateDB60_Basic.upgradeNumberSequenceTables.xpp:line 172
at Dynamics.Ax.Application.ReleaseUpdateDB60_Basic.Updatenumbersequenceframeworkpostsync() in ReleaseUpdateDB60_Basic.updateNumberSequenceFrameworkPostSync.xpp:line 32
at ReleaseUpdateDB60_Basic::updateNumberSequenceFrameworkPostSync(Object , Object[] )
at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeInstanceCall(Object instance, String MethodName, Object[] parameters)
at Dynamics.Ax.Application.SysDictClass.invokeObjectMethod(XppObjectBase _object, String _methodName, Boolean _tryBaseClass, Boolean ) in SysDictClass.invokeObjectMethod.xpp:line 42
at Dynamics.Ax.Application.ReleaseUpdateDB.Run(String methodName, sysReleasedVersion scriptVersion, Boolean force) in ReleaseUpdateDB.run.xpp:line 52
at Dynamics.Ax.Application.ReleaseUpdateExecute.Run() in ReleaseUpdateExecute.run.xpp:line 37
at Dynamics.Ax.Application.BatchRun.runJobStatic(Int64 batchId) in BatchRun.runJobStatic.xpp:line 50
at BatchRun::runJobStatic(Object[] )
at Microsoft.Dynamics.Ax.Xpp.ReflectionCallHelper.MakeStaticCall(Type type, String MethodName, Object[] parameters)
at BatchIL.taskThreadEntry(Object threadArg)
Has anyone experienced this error? please suggest a solution.
Thanks.
I have checked all the values in the number sequence tables but i do not find any records which i m getting as a error neither in AX4 nor in AX6.
Hi Kumaran,
I am also getting the same error did u resolve it if yes How? please help
Br
Raza
Have you fixed number sequence format issue. If not fix that.
Even after if you get the same error, see the batch job list (from Data cockpit form) and check for the errors and resolve them too.
