AX 2012 to external DB connectivity
But did you write this code - convert(varchar(10),res.ResultTime,120) as Sample Data - in AX 2012??
It seems for me that this code is for SQL and not Axapta
Anyway, I will try it!
Thanks a lot Piotr
Exactly like this:
objConn.Open();
cmdSelect = objConn.CreateCommand();
inventBatchId = subStr(caller.inventBatchId(), strFind(caller.inventBatchId(),’-’,1,100)+1,100);
cmdSelect.set_CommandText("select CAST(res.WorkstationId as varchar)+’
’+CAST(res.SampleIndex as varchar)+’
+"+CAST(res.Intakenumerator as varchar)+’’+CAST(res.syntheticnumerator as varchar) as recID " //+’’+CAST(dc.cid as varchar) as recID "
  • ",res.SampleIndex as k1 "
  • ",res.WorkstationID as k2 "
  • ",res.Intakenumerator as k3 "
  • ",res.syntheticnumerator as k4 "
  • ",tc.Value as LabProtocols_LabProtocolDocRef "
    + ",convert(varchar(10),res.ResultTime,120) as LabSamples_LabSampleData "
    //+ ",convert(varchar(8),res.ResultTime,114) as LabSamples_LabSampleTime "
  • ",datepart(hh, res.ResultTime) * 3600 + datepart(mi, res.ResultTime) * 60 + datepart(ss, res.ResultTime) as LabSamples_LabSampleTime "
  • ",dc.cid as CID "
  • ",dc.value as LabAnalytes_LabAnalyteValue "
  • ",convert(varchar(10),res.ResultTime,120) as LabAnalytes_LabAnalyteData "
  • ",convert(varchar(8),res.ResultTime,114) as LabAnalytes_LabAnalyteTime "
  • ",tc.Value as LabAnalytes_LabAnalyteDesc "
  • "from FIBase.dbo.DoubleComponents dc "
  • "inner join FIBase.dbo.Results as res on (res.SampleIndex = dc.SampleIndex and res.WorkstationID=dc.WorkstationID and res.Intakenumerator=dc.intakenumerator and res.syntheticnumerator=dc.syntheticnumerator) "
  • "inner join FIBase.dbo.TextComponents tc on (tc.SampleIndex = dc.SampleIndex and tc.WorkstationID=dc.WorkstationID and tc.Intakenumerator=dc.intakenumerator and tc.syntheticnumerator=dc.syntheticnumerator and tc.cid=318832640) "
  • "left join FIBase.dbo.TextComponents tc2 on (tc2.SampleIndex = dc.SampleIndex and tc2.WorkstationID=dc.WorkstationID and tc2.Intakenumerator=dc.intakenumerator and tc2.syntheticnumerator=dc.syntheticnumerator and tc2.cid=335609856) "
    //+ “where left(tc.value, 9) = '” + inventBatchId + "’ and tc2.value = ‘Średnia’ "
  • “where upper(left(tc.value, 12)) = '” + _caller.PickListJournalId + "’ and tc.value is not null and tc.value <>’’ and tc2.value = ‘Średnia’ "
  • “order by recId”);
reader = cmdSelect.ExecuteReader();
Hope this code helps! [:D]
static void TestODBC()
LoginProperty loginProperty;
OdbcConnection odbcConnection;
Statement statement;
ResultSet resultSet;
str sql, criteria;
SqlStatementExecutePermission perm;
//Set information on the ODBC
loginProperty = new LoginProperty();
loginProperty.setDSN(“dsn”);
loginProperty.setDatabase(“databaseName”);
//Create connection to external DB
odbcConnection = new OdbcConnection(loginProperty);
if (odbcConnection)
sql = “SELECT * FROM MYTABLE WHERE FIELD =” +
criteria + " ORDER BY FIELD1,FIELD2 ASC";
//assert permission for sql string
perm = new SqlStatementExecutePermission(sql);
perm.assert();
//Prepare statement
statement = odbcConnection.createStatement();
resultSet = statement.executeQuery(sql);
//Running statement
while (resultSet.next())
//It is not possible to get field 3 and then 1.Always get fields in numerical order: 1,2,3,4,5,6
print resultSet.getString(1);
print resultSet.getString(3);
//Shutting down the connection
resultSet.close();
statement.close();
else
error(“Failed to log on to the database”);
