Hi ,
I am having a different requirement altogether for a AX 2012 ssrs report.
User will be having an option to select misc charges .
parameters amount for that sales line in ax
Misc charges 1 acharge 10
Misc charges 2 bcharge 20
Misc charges 3 ccharge 30
Misc charges 4 dcharge 40
Lets say the user selects Misc Charges 1 and Misc Charges 2 then the output should be as follows
Misc Charges 1 - 10
Misc Charges 2 - 20
Other Charges - 70 (30 +40)
Other charges will be a fix column which will give the results of the non selected misc charges.
Also in case misc charge 1 is selected and there is no misc charge 1 allocated to the line then the misc column should not be displayed ,if there is data then it should be displayed.
Vikas Mehta
