I have just discovered today a strange behaviour at the PurchTableListPage and SalesTableListPage with the lines.
When you have an order with 2 or more lines. If you select the second line and you click on the itemId or make go to detail on the itemId to see the detail of the item and later you make this again but on the first line you may get the detail of the second item and not the detail of the item of the first line!!
I have just checked in a clean VPC Demo with not custom code and this bug is there. In our office we have seen it on an installation with CU3 (the last update). This is very anoying.
Have you also noticed this error? Thanks!
